ozfrog
(Donor 2026)
x 84
Unread post by ozfrog »
MattBLancs wrote: 01 Nov 2026, 14:35 Very odd, I can't wrap my head around why PSA "hid" the regen process. It's key to the engine keeping in a running condition, but a simple "regen in progress" light wasn't considered. Very odd.
On Reddit a few days ago, I saw this headline:
I created a way for me to know when my diesel (1.6 BlueHDi) is regenerating
It intrigued me, so I read further. (I've copied and pasted the person's post directly. All spelling and grammar mistakes are not mine!
If you're interested in reading the original post and comments, as well as viewing the three images, I'll post a link.
I installed a red LED into the mirror of my car and soldered it to the wires for the heated mirrors.
Recently I had to replace my DPF because it was clogged (which in turn also wrecked my turbo unfortunately) after only 80k km. I often do long drives on the highway, so I was confused why it clogged so quickly. Only thing I could think of was either me occasionally turning the car off whilst it was in the middle of a regen cycle, or something else causing the regen cycle to not fully complete, mechanic couldn’t find any weird things in the log, so I decided to do something myself. I’m hoping that with this indicator, I’ll now have an idea of when the car is regenerating, so that I’ll leave the car running, or shift into a lower gear for more rpms and a smoother regen until the cycle is complete, hopefully leading to a longer lasting DPF.
For those wondering why I did it like this:
Whenever the car regenerates, it turns on the heated mirrors and a bunch of other electrical things in order to use as much electricity as possible, forcing the engine to work harder and the exhaust to get hotter, this allows the car to burn off all the collected soot in the DPF. By hooking up an LED to the heated mirrors, I now know that if the light turns on on its own, the car is in a regeneration cycle.
If anyone else is interested in doing this, I can highly recommend it.
Cheers,
Andrew
Huskyxantia
x 928
Unread post by Huskyxantia »
Ive read that and also seen it being debunked as to some cars have auto heat setting which will switch on the heated mirrors then that led comes on too.
:-D
ozfrog
(Donor 2026)
x 84
Huskyxantia wrote: 02 Nov 2026, 10:16 Ive read that and also seen it being debunked as to some cars have auto heat setting which will switch on the heated mirrors then that led comes on too.
I presume you're referring to what I posted.
Wouldn't that LED coming on be dependent on how things were wired?
Cheers,
Andrew
Huskyxantia
x 928
More than likely I guess if it was wired to the mirror live then yes
:-D
x 1083
Unread post by Rp0thejester »
So.... It only works with heated mirrors? There must be another way to tell. Someone with vehicle electric smarts (not me) can surely figure out how to wire something together. Something in the OBD slot could be useful.
x 2367
Unread post by MattBLancs »
My understanding is the electric heated mirrors route is easy option to tap into and get an LED in the driver's eye line.
Regen cycle on going = car brings on lots of electrical load to help the engine build heat (including heated mirrors, and screen:
If you didn't have electric mirrors then the heated rear screen is also brought online (without the dash heated rear screen light coming in, sneaky!)
So you could tap into heated rear screen wiring for an LED if you didn't have heated mirrors.
Also brought on during regen is the glow plugs.
I believe (those fitted with one) the "air doser" also flicks over to bypass the intercooler, so potentially there is something there which could be tapped into
Huskyxantia
x 928
It also uses the rear window dimister, I'd take a live from one of the dpf sensors as they must trigger something
Found this
:-D
ozfrog
(Donor 2026)
x 84
Rp0thejester wrote: 02 Nov 2026, 18:29 So.... It only works with heated mirrors? There must be another way to tell. Someone with vehicle electric smarts (not me) can surely figure out how to wire something together. Something in the OBD slot could be useful.
Nor am I the person with vehicle electrical smarts.
I should have given the link to the Reddit post and discussion at the beginning. I'm sorry. Here it is now.
https://www.reddit.com/r/peugeot/commen ... diesel_16/
Cheers,
Andrew
Huskyxantia
x 928
ozfrog wrote: 04 Nov 2026, 11:37
I'd say if you or anyone wired to either door mirror live of rear demister asking as you know when you switch them on what the light was intended for then you know it will come on by itself during regen then that's ok
:-D
x 2367
Yes that's exactly it:
Rear demister (and also heated mirrors, if it has them, are controlled by the same switch) switched on by user = light on the switch illuminated.
The added mirror LED would would light up too (which doesn't tell you anything!)
But, as during a regen the demist switch light is not illuminated, but the mirrors and rear screen are switched on= added light tells you a regen is under way.
Am sure some on the forum have gone this very mod - will have a search when I get chance :)
I intend to do it on my own cars at some point but is a way down the To Do List at present.
Red 308 = I'm going to call the DPF washout a great success, no error messages this week.
Will add the figures in a bit, but last tank full worked out as 52 mpg
PaulC5
x 705
Unread post by PaulC5 »
I think Aspire_Helen did the LED mod in a door mirror to see when the dpf was regenerating on their C5 mark 1.
x 2367
PaulC5 wrote: 05 Nov 2026, 12:42 I think Aspire_Helen did the LED mod in a door mirror to see when the dpf was regenerating on their C5 mark 1.
Good memory!
viewtopic.php?p=852244#p852244
Also mentioned by others here:
viewtopic.php?p=870331#p870331
viewtopic.php?p=819851#p819851
x 8436
I must do this mod on my van ;) Thanks for all this info :cool:
ozfrog
(Donor 2026)
x 84
Why is it so important to know when the DPF is being regenerated?
Sorry, @Rp0thejester, but you can’t have all of the stupid questions! I need to be allowed to ask them as well. Thanks. 8-)
Cheers,
Andrew
x 8155
I would suggest the reason is so that you can be sure to allow the regen to complete before switching off, as well as enabling you to aid the regen by keeping the revs up if possible. :)
