Tales from beyond the grave AKA Dan & Emma's Black Xantia, pug 206HDi, Daniel's 206 Verve 1.4i, GTi180 plus XUD9TE 206!!
- x 8423
Re: Tales from beyond the grave AKA Dan & Emma's Black Xantia, pug 206HDi, Daniel's 206 Verve 1.4i, GTi180 plus XUD9TE 2
Even more curious Dan! This is getting interesting...
ekjdm14
- x 267
Indeed, another good old fashioned mystery to add to our "collection"... I will be examining the pistons & rods very closely and hopefully be able to pull some part numbers to be able to cross reference where the rods came from. Engine is sat upright again now, manifolds off and almost ready to lift the lid when the drizzle allows!
One thing worthy of note, although doubtful of any consequence, is all the rods/caps are numbered as one would do when rebuilding an engine. The numbers aren't stamped in though, they appear to be acid-etched & I'm wondering if it's a factory thing. (there is a number 1 stamped into each rod, although I'd imagine that's a tolerance identifier?) I can't honestly recall any previous XUD rods I've handled being numbered in such a way though, and surely numbering them in production would be unnecessary?
Only thing I can think of if these aren't etched from the factory, is the engine was rebuilt early in it's life/perhaps warranty? Still doesn't explain how a set of the weak DHY rods would have made their way into a DHX coded engine, because there'd be no need to number them if they were replaced either...
'96 ZX SX 1.9TD, White, 88k
'12 Mini freebie project
ekjdm14
- x 267
406 gearbox, flywheel, virtually new pull clutch, Garrett turbo & manifold swapped from the dead DHX engine to the D8A that was previously in the red 306 (exploded K14 and slipping clutch were the reasons for pulling it back out). Pretty close to being able to just drop that back in now then should be able to get Black on the driveway for her second engine replacement(!) before the exciting stuff can happen (Hopefully under cover too, for the fresh TD build)
- x 8423
Good progress Dan!
ekjdm14
- x 267
Even better. Engine is now in, wired & mostly plumbed up. Just driveshafts front end & one heater hose away from being back on the road fingers crossed. Lack of fluids stops play for now though, the engine is very low & having been nursed home on used "any oil" (better than no oil) it & filter will need a change before I'm happy to crank it over again, gearbox I thought we had a couple of litres of our usual choice Mannol 75w90 left but alas there's none (and the only ones left on ebay are £84 for 5L now, thank you messrs. Trump and Zelensky).
Will have to pay Halfrauds a visit and hope they have some suitable stuff in stock for less than an arm and leg (and wouldn't mind keeping both my kidneys too, if at all possible).
