pressure relief on system
Mark_Lancaster2026
Post by Mark_Lancaster2026 »
Hi
I am sorry if this has been previously covered but I am thinking about servicing the hydraulic system my self and was looking for some advice.
I want the replace the hydraulic pump and my Xantia and the front accumulator. I know that I have to lower the car to remove pressure from the system and then release the pressure plug to release all the pressure.
But I am uncertain where it is , on the pump its self or on the accumulator ?
are there any other pitfalls I should be aware of
thanks in advance
x 8134
Re: pressure relief on system
Post by mickthemaverick »
I think you will be able to find the Repair Procedure for that starting at: https://szervizdoksi.hu/citroen/sb.html#/v?ldp=1C2X :)
I got to this page as an example but not using your car's details : https://szervizdoksi.hu/citroen/sb.html ... CT0337&t=2
x 1491
Post by RichardW »
The pressure release screw is on the regulator (that the accumulator is attached to). Only needs to be undone a couple of turns.
x 1996
Post by Stickyfinger »
on the pressure accumulator....No need for more than a single turn ( DO NOT REMOVE the Bolt!as there is a spring and ball bearing in there) , low on the front of the engine (13mm ?)
ekjdm14
x 265
Post by ekjdm14 »
Stickyfinger wrote: Yesterday, 12:38 on the pressure accumulator....No need for more than a single turn ( DO NOT REMOVE the Bolt!as there is a spring and ball bearing in there) , low on the front of the engine (13mm ?)
12mm IIRC but the main take-away from the above, which I second, is the DO NOT REMOVE!
Also (for future reference if needed) when planning to replace the rear corner spheres, do remember to "crack" them loose maybe 1/8turn with the suspension on high (body supported for safety) before going through the depressurising. Try and loosen them with the pressure off & you'll just twist off the return lines from the cylinder boot & possibly damage the high pressure line too. Not that I speak from bitter experience or anything... :twisted:
'96 ZX SX 1.9TD, White, 88k
'12 Mini freebie project
Mark_Lancaster2026
mickthemaverick wrote: Yesterday, 12:03 I think you will be able to find the Repair Procedure for that starting at: https://szervizdoksi.hu/citroen/sb.html#/v?ldp=1C2X :)
wow thats the best information I have been able to find with part numbers
thanks for the link
