TL, DR; A fuse in the engine bay blows when I turn on the ignition with the double-relay near the ECU is connected. It doesn't blow when I turn on the ignition with that double-relay unit disconnected. I am looking for common faults downstream of that double-relay, including the double-relay box itself.
My car is a 1997 Series 1 2.0i 8v VSX. It has the 8-valve XU10J2 engine, and ORGA no seems to be 7400 if I'm looking at the correct place. The car was an auto (with the ZF 4HP14 box) but converted to manual a few months ago.
This problem started last week. The engine died while I was on the road, and both the red and green lights on the immobilizer keypad started to light up when I turned on the ignition. Checking fuses, I found that the fuse which I think is F7 in the engine bay was blown. It was a 10A fuse, but of course it may have been replaced before me as no fuse box diagrams I found showed a 10A fuse at that slot.
I replaced it with the 10A high beam fuse of one side temporarily, which gave back ignition. I left the car in the shop for brake and fluid (oil&coolant) maintenance on Thursday. I know they ran the car since Friday because they brought the engine to operating temperature multiple times.
I picked up the car today, and sure enough, the engine died at the 3rd kilometer. I pulled over, with the same symptoms. I replaced the same fuse with another 10A, which blew in seconds. Then I disconnected the battery, replaced the fuse with the 20A ABS control unit fuse. That one also blew. Finally, I disconnected the double-relay unit that was in the housing that holds the ECU and Hydractive control unit, replacing the fuse with another 20A from the interior fuse box, which did not blow.
I then reconnected the double relay thing, and that last 20A fuse also blew when I turned on the ignition.
Any ideas? A wiring diagram for the XU10J2 could also help. The fuse I'm referring to is third from bottom left in the photo (empty in the photo); above the beige 5A one and below the 10A red one.
