wheeler wrote: 02 May 2024, 19:38
HelioMV wrote: 02 May 2024, 18:35
So as long as I extract the pin from the BSI and have a tenners worth of a virgin china PCB, I can code it and it won't lock me out, brilliant!! Also, by your logic, this process can be done on newer vehicles too, such as say a 2014 or 2015 car, is that correct?
The process is exactly the same on all PSA cars with coded keys, the only difference in models from around 2018 is they have upped the security a bit so if you program a new or previously deleted key only (i.e. no working keys present) then the BSI will go into anti theft mode for around 30-35 minutes, during this time you just need to leave the ignition on till the hazzard warning lamps stop flashing then the vehicle will be allowed to start. If you have a currently programmed key & this is being re introduced in the same session then the anti theft mode wont activate.
The Fiat based models (Boxer, Relay & Bipper etc) are slightly different, It works the same as the PSA systems but if using Diagbox this will only program a new key that has been ordered from a dealer, Diagbox cant program a blank aftermarket key on Fiat sytems.
Toyota sytems on the C1/107/108 are totally different, if all the keys are lost you cant add a new key to these via OBD, the immobiliser ECU need to be replaced (or removed & re flashed by an eeprom programmer). If you have a working key you can add another key via OBD.
One of my 2 keys has ceased working, with an immobiliser error. I would like to obtain a spare and programme it.
However:
1 I have read that it is only possible to programme brand new keys (as stated on this site)
and
2 All keys need to be programmed at the same time
Now if both statements were true, if I want 2 working keys, I would have to buy and programme two of them, presumably leaving the existing one not working ?
Could anyone clarify please ?
And where do you recommend I go for the key ? ie Are the Chinese ones reliable, or should I pay some obscene price at the dealers ?
I have Lexia and the key code card.
2007 C4
