Firmware is ok, Just the maps are not update, i think the maps are from 2012Paul-R wrote: 22 Oct 2026, 12:37 So the problem isn't necessarily the firmware, it's that you're having a problem updating the maps. Or are you only worried that you're going to have a problem?
If you're already on 2.86 that is the latest and last version of firmware released.
2013 308 hdi sat/nav and pop up screen
Cafaisca
Re: 2013 308 hdi sat/nav and pop up screen
- x 1940
Then I don't see any need to update the firmware. Not that you could if you're on 2.86 already.
Check your PM in a couple of minutes for a link.
Cafaisca
Thank youPaul-R wrote: 22 Oct 2026, 15:22 Then I don't see any need to update the firmware. Not that you could if you're on 2.86 already.
