TURBO FAULT
This is the Forum for all your Renault Technical Questions, Problems or Advice.
JOE+TECH
x 4
TURBO FAULT
Unread post by JOE+TECH »
Hi problem with renault master 2.3 diesel fault code set 004516 turbo low control fault limp mode
Checked 30hg vacuum at control valve 12v at pin 1 no vac to turbo, if I earth pin 2 vac now to turbo
Can someone help with engine management wiring systen, to chech control wire from ecu to turbo control valve
Vin=VF1**************[VIN obfuscated, can be read by forum staff]
CHANGED VALVE NO DIFFRENCE
Thanks Joe
x 8126
Re: TURBO FAULT
What year is the van?
JOE+TECH
x 4
Re: TURBO FAULT
THANKS for quick reply van is 2016 2.3 diesel reault Master
VIN VF1**************[VIN obfuscated, can be read by forum staff]
Thanks Joe
x 8126
Re: TURBO FAULT
Unfortunately my backup diagrams only go to 2012 so I can't help but hopefully someone else can!! Good luck :)
