Hello all,
I have Peugeot 307 NFU 1.6 16v petrol from 2002, car is okay but I have a strange problem that I can't fix, so maybe, you can help me.
So, problem is car shudders on low throttle or maintaining speed around 2000 rpm in first 3 gears, 4th and 5th all is fine. Sometimes on idle, rpms jump from 800 to around 1100 when A/C is on, and in all occasions if I let go the throttle while driving and want to engine brake, the car dives and jerks like it has bad engine mounts. Car behaves much better (2000 rpm shuddering-wise) when I introduced it with massive vaccum leak on the inlet manifold (discconected the vaccum line going to LPG system).
Things I noticed: Lexia said I have lean mixture ( that is the only error ) but I can smell on tailpipe it is working a bit rich, I have cracked exhaust manifold on cylinder no.2 before the first O2 sensor and I have a cracked fuel tank because fuel leaks if I put more than 40 liters of fuel. Car behaves a bit worse when running on LPG, but all the problems aboive are the same.
Things I changed:
-MAP new
-Throttle body (electronic throttle) and calibrated
-Coil pack, second hand, Valeo,
-New spark plugs, Iridium, suited for LPG use
-Engine mounts
-PCV pipe
-Checked with smoke machine for vacuum leaks, all good
-Deleted LTFT/STFT
-Discconected O2 sensor, first one, for diagnostic purposes
-Discconected MAP, no change
-Pluged vaccum line for EVAP. no change
-Checked grounding wires, all good
-Checked cylinder compression, cca 15 bar all for on a dot
Peugeot 307 NFU jerking and shudder
- x 8124
Re: Peugeot 307 NFU jerking and shudder
Is your car switchable between LPG and petrol and if so does it have the issues whichever fuel you use?
vrsgaraza
Yes, it is sequent type LPG, and it has same problems on both fuels, only a bit worse when running on LPG.
