Hi,
Can anyone help me?
I have a C5 X7 1.6 HDi... I’ve replaced the timing belt, and everything was done according to the diagram—the holes align perfectly with the locking pins.
When I start it up, it idles very smoothly, but when I press the accelerator, the engine almost stalls.
I’m getting error code P0339 (crankshaft sensor)... I’ve replaced the sensor, but I’m still having the same problem—the car almost stalls when I hit the gas. I’m completely stumped... what’s wrong?
Best regards
Dag M
P0339 fault code
- x 8125
Re: P0339 fault code
Have you checked the condition of the wiring to the sensor and its plug pins?
DM3003
Hi..Thanks for the reply... yes, I've replaced the connector.
But the same error code keeps appearing.
- x 1489
Possibly you have damaged the pick up ring on the crank sprocket; or maybe the air gap is wrong - there's a locating pin, but it often breaks off.
DM3003
Hi Richard
The crank sprocket is new.
- x 1489
- x 1489
Well at least it wasn't Amazon, but my guess is it's no good. Was it a branded one?
DM3003
Hi Richard
It was maxgear 54-1103
DM3003
I cleaned the magnetic ring that the sensor sits on today... after that, the car won't start... and it's the same error code, P0339
- x 1489
Looks like you will have to replace- preferably OEM. What happened to the original one?
DM3003
I had to remove the old one to replace the crankshaft seal... I damaged the ring while trying to pull it of
DM3003
Started it up today... it idles fine... but stalls when I give it gas... same error code P0339.
