Hi
Its my first time on this forum, hopefully you guys can help me with this.
I initially had an issue with my fan being slow/weak on every setting except the maximum and looked online and saw that the heater blower fan motor resistor (6441S7) was the likely culprit. I ordered it on ebay from one of the top sellers of this item and fitted it and it worked well for about an hour in total of driving.
After I had parked my car and then got back in to drive away after a few hours of being idle the fan went to full blast and I could not stop it either by turning it down or turn or turning it off. I have had to remove the relevant fuse to stop the issue.
I am thinking it may be a faulty replacement part at fault but keen to hear your guys' thoughts on whether you agree or whether I should check something else first.
Mark
2014 DS3 fan on full blast, won't stop
- x 8166
Re: 2014 DS3 fan on full blast, won't stop
You may be right and it may be a faulty new part but I would suggest you measure the fan's motor coil resistance and if possible the current it is drawing when set to each switch position. You may have a partial short circuit to earth somewhere causing it to draw too much current and damage the resistor pack.
