508 RT6 version 2.07
This unit is the eMyWay system, also referred to as RT6, RNEG2, or WIPNAV+ for the Peugeot platform and made by Magneti Marelli.
Main Features: The eMyWay colour satellite navigation has high resolution mapping, Bluetooth Telephone & Audio Streaming supported profiles, USB support for Media files & CD
508
Unread post by 508 »
Hey everyone,
My eMyWay system is running version 2.07.
I tried to update from a CD ISO using a USB, but that didn't work.
I want to update it as Bluetooth is spotty and disconnects midway through a song, and I would like to use MiraScript properly with some maps that aren't from 2012.
Does anyone have any tips or files for the upgrade from 2.07 to 2.86B?
x 1953
Re: 508 RT6 version 2.07
If you simply copied the ISO onto the USB stick then that certainly won't work. You need to copy the contents (files and folders) to the root of the USB stick. You will probably need to use a program to mount the ISO as a virtual drive.
But it was probably a good thing that you didn't go straight to 2.86. If you look at this table download/file.php?id=83044&mode=view you will see that the only safe upgrades from 2.07 are 2.20 and 2.21. I only have 2.21 and I will send you a link to that in five minutes. It's all ready for a USB stick as it's been extracted from an ISO
If you go further than that you will need to get the configuration restored as yours will be lost. You should use MiraScripts to save your configuration to a USB stick. A guide is here viewtopic.php?p=866819#p866819 I would strongly suggest you save your configuration even for a first step. At worst you can pay a dealer to upload the configuration from the French servers.
If this update installs but doesn't work I can send you links to later version softwares.
Map updates we can sort at the end.
508
Hi all, just bumping this from September: I am still on firmware 2.07 on my 2012 508 Saloon SR and getting a "Corrupted" error trying to update to 2.86. If anyone still has a link to 2.21.A.1 (or 2.37), I would really appreciate it!
