RT6 2.75.c.5 Firmware / Software Download
Fredo2b
Re: RT6 2.75.c.5 Firmware / Software Download
Sorry, I didn't receive anything.
- x 1941
You won't receive it. You have to go into the PMs (personal messages) and click on the message from me to open it up. Inside the message at the bottom is the link.
You must have at least glanced at the PM because it's in my 'Sent messages' folder rather than the 'Outbox'. The 'Outbox' is where messages go as soon as I send them. When the recipient opens his PMs the message moves to 'Sent messages' so I know they have received it.
Fredo2b
Oui, je l'ai bien reçu mais le lien ne fonctionne pas. En avez-vous un autre ? merci
- x 1941
The link has worked for everyone else I have shared it with. I have just clicked on the link in the PM and it works for me.
What exactly is not working for you?
Fredo2b
Désolé, j'ai fait une fausse manipulation et j'ai perdu le lien. Pouvez-vous me le renvoyer ?
Fredo2b
Bonjour. J'ai bien reçu le lien, fonctionnel, pour le logiciel 2.77. Mais, le RT6 ne veut pas le prendre en compte, l'écran reste noir et le bruit du CD est toujours présent. Auriez-vous un lien pour les versions suivantes ?
- x 5674
English, please.
- x 1941
I have 2.80, 2.85 and 2.86. I will PM you the links.
coco13
Hello everyone,
I am looking for some help with an RT6 (RNEG2 CEM00) unit from a 2014 Citroën C5.
The unit powers up, the button backlighting works, the cooling fan runs continuously, and the CD mechanism attempts to initialize every 10-15 seconds. However, the screen remains completely black and the Citroën logo never appears.
I have already backed up the original 8 GB microSD card using Win32DiskImager and tested a cloned card, but there was no change in behavior. The same symptoms occur even with the microSD card removed.
As far as I know, the unit has never received a firmware update since the car left the factory.
Could someone please provide the correct firmware (preferably a recovery version) or suggest the best recovery procedure?
Thank you in advance for your assistance.
- x 1941
If you've had the RT6 unit out did you notice whether there was a sticker showing the version of firmware fitted?
coco13
Unfortunately, the installed software version is not specified on the device.
- x 1941
I will send you links for 2.77, 2.80, 2.85 and 2.86. Start at the lowest and work your way up. Hopefully you will find a version that works. Unfortunately I can't check my 2013 C5 X7 to see what's fitted there as I had new unit fitted under warranty in 2016.
coco13
I'll try it just as you suggested. Thank you. I'll get back to you with an update.
- x 1941
Of course if your SD card is on its way out, none of that will work. Even worse, if the electronics of the unit are ailing that will also cause problems.
Good luck.
Good luck.
coco13
Hello, I managed to install version 2.86 from the CD. It works very well, except I don't have the maps and the Peugeot logo appears at the beginning instead of Citroen. In any case, thank you so much for your help!
