- x 2361
Pulled and pushed and shoved and heaved and can't get gearbox to sit against the block. About 15mm away. Pulled box off again, phone shoved in to check alignment of clutch and hole in flywheel= seems good. Annoying.
Sun baking me now, hot!
- x 2361
- x 2361
Huskyxantia
- x 924
Nice one , I'd say that will do a better job than cable ties especially being a diesel aswell move force and all that good stuff..
Husky.
- x 2361
Got the box into place (after a good hour and a half fighting it!)
Engine and gearbox mounts all back on.
One (long) driveshaft back on, and wishbone reassembled.
other short shaft needs outer boot replacement then can go back on.
To do:
To do:
- Driveshaft fixed and on,
- other wishbone back together.
- gearbox oil in,
- bleed clutch,
- check gear selector alignment ok (turns out what I loosened first in the cables is for length adjustment!).
- Tighten both hub nuts.
- Arch liners in.
- Decide if under tray can be fitted or more pre work on that.
- Battery tray, ECU, battery, air filter housing.
- Maybe brake bleeding (depending on how much fluid level dropped, as capping clutch line wasn't that effective so a fair bit lost. Fresh brake fluid always a good idea.
- x 2361
Yes, pleased with that clamping effort. Not sure how long lived the stretch boot will prove to be - the rubbery material feels very thin!Huskyxantia wrote: 19 Aug 2026, 19:52 Nice one , I'd say that will do a better job than cable ties especially being a diesel aswell move force and all that good stuff..
PaulC5
- x 698
It is good of you to post all this and I find it interesting/enjoyable to read. A pity the work needs doing but the car will be good for a long time afterwards.
- x 8422
Oh gosh, I feel for you Andrew... You must feel a bit like I did newly arrived in your country and trying to learn the languageozfrog wrote: 19 Aug 2026, 07:04 Clacton? Clacton-on-Sea? Constituency? What on earth?
And a retired stripper?
Another case of two countries being divided by a common language; at last you down-under have a 'U' in your alphabet and use it properly
All very good work accomplished Matt
- x 2361
Good, mission accomplished if an enjoyable read!PaulC5 wrote: 19 Aug 2026, 22:47 It is good of you to post all this and I find it interesting/enjoyable to read. A pity the work needs doing but the car will be good for a long time afterwards.
Thanks Jim
Currently chucking it down - hoping that does not last too long
Huskyxantia
- x 924
Did you remove the front extension part of the sub frame ?
Husky.
- x 2361
No, there isn't one on this generation of 308. I didn't get the box fully out (couldn't quite seen to get it through) and doing it again I'd probably consider dropping the subframe....
...though considering how crusty stuff is, that could be a can of rirm in its own right.
Brightening slightly (and my two boys packed off with their grandpa for the day) so about to head out. CV boot job first so no pictures whilst elbow derp in CV grease!
Huskyxantia
- x 924
Have a great session today matt and make use of them dry spells too
Husky.
- x 8144
I realise this is reminiscent of bolting the stable door............... but I came across this and thought it was relevant to the current work and of interest to readers: https://www.ebay.co.uk/itm/366416577021
- x 2361
Ha, that was optimistic!
CV boot job done. Video of the other end in a moment - an odd "failure" at that end.
- x 2361
Thursday morning update:
Various grotty M6 threads chased out with tap.
To do
- Driveshaft fixed and on, DONE
- other wishbone back together. DONE
- gearbox oil in, DONE 2.1 litres 75w80 fully synthetic via breather hole.
- Battery tray, ECU, battery. DONE
To do
- bleed clutch, NOT YET DONE
- Tighten both hub nuts. NOT YET DONE will torque fully after lunch (set at 250 Nm now (torque wrench max) needs 325 Nm.
- air filter housing + Air flow meter connector
- Arch liners in.
