308CC Steering wheel to regular 308
nikeastwood
x 24
Unread post by nikeastwood »
on a similar year car
can I put in a 308CC steering wheel into a normal 308? both steering wheels are just the regular airbag ones, not the later ones with controls on.
I suspect yes, just want confirmation.
ta
no egr, no dpf, no problems.
x 8151
Re: 308CC Steering wheel to regular 308
This ebay seller has very good feedback regarding questions, it may be worth emailing him your query which I expect he will view as a possible sale and hence help you out! Good luck. :)
https://www.ebay.co.uk/itm/267715160046
x 1473
Unread post by xantia_v6 »
You would need to check that the electrical connectors for airbag and horn are compatible, but if they are from the same generation of 308, then it should be fine.
nikeastwood
x 24
it fitted with no problems at all, I reused our original air bag which was the same shape.
