Recommend an OBD2-ECU device for Citroën C4 Picasso 1.6HDi (2008) ?
Sparxz
Hi Guys,
Can anyone please recommend an OBD2-ECU device to read, do some diagnostics,
and clear codes for a Citroën C4 Picasso 1.6HDi (2008) ?
I have watched so many videos on youtube, and none the wiser.
In particular, currently I am trying to monitor and clear DPF faults.
I usually buy old cars(at least 10yrs old), and do not need anything that is for new cars, or hybrids, EV.
There must be something ?
Thanks.
Thanks.
cit-rotti
- x 77
Re: Recommend an OBD2-ECU device for Citroën C4 Picasso 1.6HDi (2008) ?
Only the Diagbox (LEXIA) with the stable software 7.57 or alternatively 7.62 is really useful for hobby mechanics for PSA vehicles up to approx. 2015.
Then everything can be read/deleted and changed via offline diagnostics - with the exception of online updates for control units.
With a proper full-chip interface, all PSA models can be diagnosed. And the interface can then be used later for higher-level software (Diagbox 9.xxx).
A laptop with dual processor and Window XP prof. 32 bit or WIN 7 Pro 32 bit is required for the Diagbox software 7.57.
For Diagbox Software 9.xxx, WIN10 pro 64 bit with appropriate performance should preferably be available.
Recommendation:
The software version should be selected depending on the laptop available. Older vehicles can of course also be diagnosed with a higher software version. However, the 7 software is particularly stable and unaltered - but only works up to 2015.
Depending on the laptop performance, there are VM installations or native installations.
VM software is usually available free of charge online. Native installations are sometimes free of charge or for an activation fee.
Greetings Wolfgang
Recommendation:
Greetings Wolfgang
Sparxz
Hi Wolfgang,
Thanks so much. Found a link to download Diagbox from the berlingoforum.com forum. Downloading now.
Look forward to trying this out.
When I was looking for "Diagnostic Tool Lexia 3 Full Chip V7.83 OBD", the cheapest I found was €118 on Amazon.co.uk.
I have a cheap bluetooth OBD2 device to connect to Android.
But there must be something surely, that works with the "Lexia 3 Full Chip" that costs less than €118 ?
cit-rotti
- x 77
Bluetooth OBD2 devices can very rarely do more than read out the standard ECU, delete errors there and make a few changes. If this is enough for you, you will be fine. This can also be very useful for deleting errors in the standard ECU when travelling.
However, most vehicles from 2008 usually have 20-30 ECUs - newer vehicles have even more, of course - and these can only ever be diagnosed with the respective company-specific software. Even high-quality diagnostic tools from Bosch/Gutmann (3000-5000€) etc., which can be used by workshops, can do a lot but not everything.
In the case of Citroen, this is the Diagbox for a 2008 model.
Cheap VCIs are usually a problem - 11 out of 10 VCIs usually do not work properly - especially with software from firmware 4.3.0 (AB Diagbox 6.xx).
The Danes buy their Chinese clones from
https://lifafadenmark.com/
and are very satisfied - I don't think that around €100-120 is particularly expensive - good manual tools always have their price.
Free or cheap, proper software with installation videos can be found, for example, at
https://guiapsa.foroactivo.com/login
With the purchase of a VCI you usually get suitable software.
Greetings Wolfgang
Greetings Wolfgang
rocco
- x 3
I couldn't figure out the Diagbox/Lexia/VCI stuff so I bought a Topdon device which, like Wolfgang has said, is good enough to read and clear fault codes. I definately paid more than €120 for it too. I just seemed less pfaffing about a laptop and it should work with a lot of other cars too.
CitROeNALD
- x 10
Further to the opening post:
I have a C4 Grand Spacetourer (2018). As it's getting on for 7 years old now, I really would like the ability to check the car data/diagnostics without being charged extortionate amounts from the garage.
I assume the most comprehensive solution is setting up the diagbox. From the info above I would need a full-chip interface, and software (Diagbox 9.xxx)? Or am I mistaken.
1) Does this mean I need to download the correct/latest software
2) Acquire the cabling and interface box (is that what is meant by full chip interface?).
Is there a comprehensive guide as to equipment sourcing and set-up? I can find bits of information here and there, but I am not sure how out of date some of it is, especially for newer model cars.
I'm pretty computer literate, so I'm sure I can manage, but I like to be sure of the information source.
Failing that, although I understand most OBD2 readers don't give all the information with modern proprietary ECU's etc, but, are there certain reader brands/models that are known to work well with citroen, especially at a competitive price point?
cit-rotti
- x 77
Everything is correct:CitROeNALD wrote: 24 Jan 2025, 21:29 Further to the opening post:
A 2018 model requires the Diagbox 9.xxx.
The decision whether to install a VM installation or a native version depends on the laptop you have available.
The problem with a 9.xxx installation lies in the variety of versions offered. They all claim that their version has all the elements of the original software. But this is not true - most of them steal a software version from somewhere and copy some new features and then claim to be up-to-date.
The higher the software, the more up-to-date it is and newer vehicles/ECUs are recognised.
As a VM version, 9.68, which was stolen from the native installation 9.68 by MrRorry (50€ activation costs), was very stable - but only lasts until 2021.
Currently, the native version 9.216 (activation 15€) is probably a reasonable installation.
But there are many free native and VM versions. If necessary, you have to try and reinstall.
The only important thing is a good VCI - the rest can always be solved.
See my tip:
and are very satisfied - I don't think that around €100-120 is particularly expensive - good tools always come at a price.
Greetings Wolfgang
CitROeNALD
- x 10
Just to follow up on this,
Are there a lot of poor quality interface boxes around/available to buy, even if they look legit or exactly the same as that danish supplier?
- x 1070
Unfortunately when it comes to money being spent there are a lot of dodgy boxes out there. I got mine from Easy Diagnostics and it is the real deal. I trust them and I'm sure many more from this community do as well.
Champion of Where's CitroJim
parnell
- x 12
Easydiagnostics is great indeed... on top of the diagbox I just ordered a Nexas obd tool with which I intend to use the FAP app in order to monitor the DPF operation on the Citroen at least for the next few thousand kms - diagbox is great but I cant be having a laptop constantly hooked up...
CitROeNALD
- x 10
If you do have a laptop hooked up, does the diagbox do live data logging that you can export etc?
parnell
- x 12
Yes it can track and export live dataCitROeNALD wrote: 29 Jul 2026, 00:34 If you do have a laptop hooked up, does the diagbox do live data logging that you can export etc?
ozvtr
- x 251
IMHO the "scanner tool" part of LEXIA is quite poor. For some engine ECUs it will not even provide long term fuel trims! Even the little ELM scanners will provide that! The best that I can say is that it's acceptable.parnell wrote: 14 Sep 2026, 12:21Yes it can track and export live dataCitROeNALD wrote: 29 Jul 2026, 00:34 If you do have a laptop hooked up, does the diagbox do live data logging that you can export etc?
99.9% of the ACTIA3 scanners on the market are Chinese knock offs. Make of that what you will. "You pays yur money, you takes yur chances". The biggest problem is the software. That's pirated too. You have to stand on your head and face south to get it to work. I would highly recommend buying it from a place that will refund money if it doesn't work!! Get the "full chip version". The ACTIA3 scanner struggles to recognize ECUs in later model cars if the scanner is the earlier revision.
If you only need information from the engine ECU, the little ELM based scanners work fine. Some will even graph live data (which is very handy).
If you absolutely have to have data from any of the other ECUs in the car, then you will need a LEXIA or a professional scanner.
CitROeNALD
- x 10
So easy diagnostics is a reputable supplier and the product is good quality?
Is the Diagbox version it comes with a good stable version?
Is it likely to be as good as that danish import @cit-rotti linked to earlier?
I was very tempted as the price quoted is about £130 for that one, but I realised once I add on import duty and postage it climbs up towards the £200 mark too (from what I have calculated anyway).
I guess my final few questions before making a decision are:
How much more useful is Diagbox as a tool for maintenance and monitoring vs a good quality off the shelf diagnostic tool with similar capability?
What would the cost for something off the shelf diagnostics be to have equivalent functions, are we talking £400 or upwards of £1000 and a fully functional launchuk type tablet.
The car is getting on for 9 years old now, and I would prefer to have the ability to diagnose stuff rather than being charged £100 for the privilege at a garage if stuff starts to go wrong.
- x 2005
100% good, HIGHLY recommended
