Can't Update RCC Wave 3
This section is for information and posts relating to Audio Head Units, and Navigation Systems
tunahan12
Unread post by tunahan12 »
Hello guıys, i have 2020 C-Elysee with original RCC multimedia. I'm trying to update unit but everytime it says ''usb key isn't compatible with this vehicle'' and i can't fix it. Tried to update using Citroen Update, PSA Update and many more but no solution. Can you guys help me to fix it? Thank you so much.
x 8121
Re: Can't Update RCC Wave 3
I have moved this here where you are more likely to get some help. As I see you have already posted the same question on another thread I will lock this one to prevent duplication. Please don't post the same problem in different areas, it only causes more work and won't help you at all :)
