2020 Citroen relay air conditioning
lieberty64
Unread post by lieberty64 »
Hi, l have a 2020 citroen relay, bought few months ago, and I never had the aircon working. Been through few "experts" but still not working
Got new condensor, been regased & holding pressure
Air con man said that the high & low pressure switches are fine
Fuses and relays check fine
Compressor working when given 12v directly
Light on the switch comes on when switched on, but doesn't activate the compressor
Any fresh thoughts anyone???
x 8121
Re: 2020 Citroen relay air conditioning
Have you reset the BSi following the link below since replacing the condensor? :)
viewtopic.php?p=601679#p601679
PaulC5
x 685
Unread post by PaulC5 »
If none of the experts were Citroen dealers I would try one for a diagnostic to see what is wrong.
lieberty64
Been to them, said I believe there is an electrical issue, but they never got to check the electrics. They done leak test, said that the condenser is leaking (£199) & quoted £1300. You can buy a new condenser for £60, I went upmarket and paid £150.
I will go back, if I must, but just talking to reception is 199
