Hi, I have a peugeot 508 with RT6 and already have 2.21 version of software. Do someone have the 2.86 to download? I’ve got something but when i put the pendrive into and waited like 10 minutes it displayed that the files are incomplete or damaged.
I will be grateful for the file. Thank you in advance for your help.
Looking for RT6 2.86 software
- x 7930
Re: Looking for RT6 2.86 software
I have moved this topic here which is a more appropriate area for your issue. You have posted the same basic request twice, the other post at viewtopic.php?p=871457#p871457 has been locked to avoid duplication and confusion.
stek71
Sure, thanksmickthemaverick wrote: 14 Jul 2026, 13:17 I have moved this topic here which is a more appropriate area for your issue. You have posted the same basic request twice, the other post at viewtopic.php?p=871457#p871457 has been locked to avoid duplication and confusion.
- x 1900
stek71
I’m sure I want to update, i’ll use the MiraScript to copy my settings.Paul-R wrote: 14 Jul 2026, 15:45 Have a read of this and then decide what you want to do.
viewtopic.php?p=860696#p860696
I just need files because I cannot find.
- x 1900
Do you want links to all the intermediate upgrades as well so you can progressively upgrade?
stek71
Why not, you can send whatever you've got and could be useful.Paul-R wrote: 14 Jul 2026, 18:40 Do you want links to all the intermediate upgrades as well so you can progressively upgrade?
- x 1900
Check your PM. Usual disclaimers. Use at own risk, etc.
stek71
Do you also have mirascript to do a backup?
And would you recommend updating directly from 2.21 to 2.86, or is it safer to install the intermediate versions first?
- x 1900
I do have Mirascript V01.04 which I downloaded some years ago so there may be a newer version out there somewhere. I'll PM you a link in a few minutes. Please don't ask me questions about Mirascript as I've only ever used it to download the configuration (which I fortunately haven't had to use) and remove the requirement to input a code when inputting new maps. I am absolutely no expert with this.
See this post, and surrounding posts about updating from 2.21. viewtopic.php?p=860696#p860696
stek71
Thanks for your help, I’ve already installed 2.86b and everything is fine.
