5008 mk1 AC condenser change
amazighman
Unread post by amazighman »
Hi all.
I had my AC system checked ( 5008 MK1 2.0 hdi 2011 )for leaks and the garage found out that the AC condenser has a hole and needs changing.
I have ordered a replacement NRF which should be here soon
Bumper has to come off without a doubt , but do I need to remove the cooling fan as well? Coolant Rad brackets?
Anyone has any advice or the " how to " PDF from Peugeot?
x 8147
Re: 5008 mk1 AC condenser change
Here you go: :)
Condenser pdf.pdf
5008 Condenser replacement
(756.56 KiB) Downloaded 140 times
amazighman
mickthemaverick wrote: 18 Jun 2026, 09:08 Here you go: :)
Condenser pdf.pdf
Thank you Mick.
That looks a big faff..
I have seen some video for C4 Picasso where you unbolt the two T30 radiator brackets and push the rad back and lift the ac condenser up...
Wonder if it will work for 5008
amazighman
Is there a shortcut or the job has to be done as per repair manual ,?
