Hi,
While driving my C4 make year 2009 I got a gearbox ( AL4 ) fault P1167 "Automatic gearbox Pressure Regulation Fault". Using Lexia I read the oil pressure at idle. The measured pressure was 4.9 bar instead of the expected 8.9 bar. At the very moment the fault was triggered the symptom of the fault was a slight vibration of shifting from 1st gear to 2nd gear and the gearbox got into limp mode and stacked on 3rd gear, but this symptom the car drove well. Turn the car off cleared the fault but the vibration stayed. After the fault triggered I drove about 7 miles ( the fault triggered couple of times till I got home, turn the car off and on cleared it ). Next day when I wanted to drive to garage after driving 5 seconds since starting the car, the car wont move like the clutches are slipping. I know that the solenoids regulate the oil pressure and when a solenoid gets faulty the oil pressure is not regulated correctly.
I don't think it is a slipping clutch/s since at the very moment it happened but the vibration on gear shifting the care drove well. It all started the next day after not driving the car for a day and let it cool down.
Can it be that a faulty solenoid will cause this problem ? Can it be that at the very moment it happened the because the faulty solenoid was warm the gear still functioned ( with the vibration ) and after overnight when gear and solenoid got cold the car wont drive ? BTW even when the car is not move the fault is not triggered .
Zohar
Citroen C4 from 2009 - AL4 fault P1167
lancia58
- x 8
Xantia 2.0 16V Automatic make year 2000 LHD
Citroen C4 THP Automatic make year 2009 LHD
Citroen C4 VTS 2.0 16V make year 2006 LHD
- x 8144
Re: Citroen C4 from 2009 - AL4 fault P1167
It could indeed be a solenoid problem, but it could also be a sudden loss of gearbox oil. I'd suggest a first move is to check the oil level and then go from there.
lancia58
- x 8
If it is a sudden oil loss how comes that I was able to drive home ? Can the oil loss after I parked the car ?
Zohar
Zohar
lancia58
- x 8
Hi
Any idea ?
Zohar
Any idea ?
Zohar
ozvtr
- x 253
There are two classic faults that cause the "pressure regulation" fault. One is the main pressure regulation solenoid valve and the other is the pressure sensor on the bottom of the gearbox.
9 times out of 10 it's the solenoid. If you can get readings from the pressure sensor that make some sort of sense, then it wont be the sensor. Typically, a faulty sensor just spits out garbage.
lancia58
- x 8
If the pressure sensor is faulty can it be the cause that the car will not move like a slipping clutch ? As I described in the post opening this thread I got the fault during driving and but the vibration on gear shift the car drove well . I was able to get back home and park the car. Next day the car drove for 5 seconds and then it will not move at all like the the clutch is slipping.ozvtr wrote: 14 Jun 2026, 04:14There are two classic faults that cause the "pressure regulation" fault. One is the main pressure regulation solenoid valve and the other is the pressure sensor on the bottom of the gearbox.
I have to add that I replaced the pressure sensor two weeks before I got the P1167 fault, The pressure sensor is not a genuine but from Meat & Doria a very good aftermarket part supplier
Zohar
ozvtr
- x 253
In this case I don't think so. The sensor appears to be giving good data.lancia58 wrote: 14 Jun 2026, 06:24 If the pressure sensor is faulty can it be the cause that the car will not move like a slipping clutch ?
The clutches and the brakes in the gearbox are actuated by the pressure of the hydraulic oil. This pressure is regulated by the main pressure regulator valve. So high pressure oil comes off the oil pump to the Solenoid valve which regulates it down to the pressure required by the control module. If it doesn't provide enough pressure, the clutches and brakes wont hold.
The solenoid valve controls the pressure by modulating. That is; by switching on and off. If you put the car in D or R you can hear the valve buzzing over the sound of the engine!! So it's working VERY hard. That's why they fail so often.
Was the wiring damaged from road dross?lancia58 wrote: 14 Jun 2026, 06:24 I have to add that I replaced the pressure sensor two weeks before I got the P1167 fault, The pressure sensor is not a genuine but from Meat & Doria a very good aftermarket part supplier
lancia58
- x 8
Hi,
What will be the symptom in case there is no electrical contact between the gearbox ECU and the pressure regulating solenoid ?
Zohar
Zohar
Xantia96
- New User
Hi
I have a 207 cc with an AL4 box that is due for an oil change. Does anyone have any experience of outfits who undertake this? (I am based in SW Herts). Is Lexia still necessary to reset the wear counter?
ozvtr
- x 253
Changing the oil is not difficult. If you are confident that the oil has never been changed, then just drain the oil and measure the amount that came out. Then put back that exact amount. If you are unsure, then I would do it properly. If it's been changed before then it may not have been done correctly.Xantia96 wrote: 22 Jun 2026, 21:46 Hi
Your local mechanic should be quite capable of doing it.
The specification for the oil is Esso LT71141. I am NOT going to go into replacement or equivalents. That's a whole other tin of worms!
IMHO the wear counter is B/S. The gearbox does tell you when the oil is at its "end of life" (from the counter). But then the manufacturer says the gearbox is "sealed for life"!! Then they give you instructions on how to change the oil!? NO!! THE OIL WILL NOT OUTLAST THE GEARBOX. IT NEEDS TO BE CHANGED PERIODICALY!
Besides, in a single drain, it's not going to drain all the oil. There is still a lot in the torque converter. So what are you going to reset the counter to?
Don't worry about it, I doubt that the oil warning would ever come up while you own the car.
IIRC there has only been one incidence where a member posted that they had the AL4 gearbox oil warning come up!
