Hi forum,
I have a 2006 Citroen relay 2 with an p0190 problem I have changed pressure sensor and check wiring to ecu but for the life in me the engine light will not go out
i have also checked fuel shut of selonide when checked on diagnostics live data actual and desire are both at 400 bar please could some one advice what else it could be 2.2 engine
Citroen relay 2.2 p0190 problem
- x 8149
Re: Citroen relay 2.2 p0190 problem
Having replaced the sensor did you go into the fault log and reset the fault? As it was recorded as a permanent fault it needs resetting before it will extinguish the light!
N0rth3rner
Hi Mickthemaverick i have reset /tried to clear code but it cuts out but not fully cuts out and engine light stays on
- x 8149
What are you using to reset the codes?
N0rth3rner
snap on also tried topdon
- x 8149
I'm not sure what the 'it' is in your phrase: "but it cuts out but not fully cuts out" ?
N0rth3rner
when I reset engine light it comes straight back on and when engine is running and I try to clear fault the engine cuts out but not fully cuts out as still running but fault will not clear.
N0rth3rner
and in limp mode sorry
- x 8149
I'm afraid I'm not following you. You shouldn't be trying to reset the codes with the engine running, just with the ignition switched on
N0rth3rner
yes i know but even with ignition on and clearing code/codes the code will not clear.
- x 8149
It may be worth finding someone with Diagbox and seeing if you can reset it with that.
N0rth3rner
ok thanks will try find some one with that and get back to you thanks again.
- x 8149
We have a list of members with Diagbox. Read through the prelim prose and then you may be able to find some help:
viewtopic.php?p=509922#p509922
