Hi
Hoping someone may be able to help.
My daughter has a 2018 DS3 2018 3 door and the drivers door is leaking in the heavy rain. There seems to be 2 seals on the door frame, a top seal and 1 that goes around the door frame. I cant find a part number or the top seal anywhere online only the seal that goes all around the frame. Any ideas on that top seal? Any advice much appreciated.
Many thanks
DS3 2018 Door Seals
Burnsy74
DS3 2018 Door Seals
PaulC5
- x 632
Re: DS3 2018 Door Seals
Make sure the door drain holes are not blocked.
- x 7947
I am not sure which part you are calling the top seal. It may be known as a wind deflector but could you post a pic of the one you are referring to?
eg, have a look at this: https://edgevisors.com/collections/ds3-wind-deflectors
Burnsy74
Thanks for the replies. New on here not sure how to post pictures. There appears to be an inner and outer rubber seal. The outer looks possibly damaged. Do have pictures but not sure how to upload.
- x 7947
Burnsy74
Should be some pictures uploaded now
- x 7947
That does look like damaged wind deflectors as per my post earlier.
Burnsy74
Thanks but the wind deflectors fit above the window on the door itself.This is attached to the body of car above the door seal, not on the door itself. Confusing as cant find part online.
