Peugeot 508 (2016) 2.0 HDI - Gear Box Filler/Drain Location
Gerry_123
Unread post by Gerry_123 »
Hello, May anyone provide location of Peugeot 508 (2016) 2.0 HDI - Gear Box Filler plug & Drain plug location ?
{Setup: 508 (2016) 2.0 e-HDI Start/Stop {DiagBox 9.68 via VMWare). Using: Best Lexia 3 Diagbox V9.129 Full Chip 921815C Golden Edge Diagnostic Tool V7.83 PP2000 Lexia3 }
x 8120
Re: Peugeot 508 (2016) 2.0 HDI - Gear Box Filler/Drain Location
Could you confirm which gearbox you have? :)
Gerry_123
Six speed manual or do I need provide a designation, if so how to check ?
x 8120
Does this help?
3008 9HD Transmssion.pdf
Gearbox info
(183.63 KiB) Downloaded 73 times
Gerry_123
I will check. Regardless, thanks for your response.
