2006 berlingo speedo cluster replacement.
cwm ni
Unread post by cwm ni »
I am trying to replace the instrument cluster on the dash of my 2006 Berlingo multispace but struggling to find the exact part number to match the original . Are Citroen speedo cluster part numbers 9659365480 and 000709514 interchangeable? They look identical but not 100% sure . Any advice would be appreciated.
x 8084
Re: 2006 berlingo speedo cluster replacement.
I have no idea whether they are compatible or not but personally I'd hold out for the one which matches your existing part. :)
shtu
x 76
Unread post by shtu »
There's a matching part number cluster on eBay for £25 right now, open to offers.
Why make life hard for yourself? :)
PaulC5
x 675
Unread post by PaulC5 »
Beware that if you fit a used one with a higher mileage than your existing, then the car will adopt this higher mileage. You should take photos of your mileage before and after as you may have problems with insurance if your policy has a mileage limit and you may need to explain it.
cwm ni
shtu wrote: 20 May 2026, 21:16 There's a matching part number cluster on eBay for £25 right now, open to offers.
Any chance you could send the link please it's the 000709514 that i need . Thanks for your help.
