Presión esferas Citroen Xantia 2.0 8V
BGK_799
Unread post by BGK_799 »
Procedimiento de Cambio y si son reparables?
También hay ciertos mecánicos, que están eliminando el sistema BAP ( LHM), original por un sistema Booster y están inventando un Dosificador hechizo, con sus concebidas consecuencias.
Trabajo antitecnico y buscando vender los Autos, por partes y prácticamente, como chatarra.
Gracias
x 5673
Re: Presión esferas Citroen Xantia 2.0 8V
Please post in English!
Translated post:
Brake pressure [doseur valve?] for Citroën Xantia 2.0 8V
Replacement procedure and are they repairable?
There are also certain mechanics who are removing the original BAP (LHM) system and replacing it with a booster system, and are improvising a makeshift metering unit, with all the consequences that entails.
This is unprofessional work aimed at selling the cars for parts, effectively as scrap.
Thank you
Translated using DeepL
Reason: Improved translation
x 2000
Unread post by Stickyfinger »
That has got to be the strangest Xantia post I have seen for some time :)
x 1938
Must admit I don't really know what it's about.
x 5673
As far as the doseur valve is concerned, I recall them being very difficult to source a decade or more ago. It seems that JCB use them in their excavators and some had purchased from there.
For the second part, that remains a mystery. Clarification required.
