diabox 7.57
peugeot sw lover
diabox 7.57
Unread post by peugeot sw lover »
Hello, could anyone provide me with a good link of diagbox 7.57 non vm as one version or as updates from version 7.40 as this is the last version I am able to install successfully? Thanks a lot.
x 1944
Re: diabox 7.57
Please confirm exactly what version you have at the moment and what you want to end up with. I am a bit confused.
What does non vm mean?
Mihael_M
x 37
Re: diabox 7.57
Unread post by Mihael_M »
In French, it probably suits you.
https://www.psa-diag.fr/forum/diagbox-t3110.html
ozfrog
(Donor 2026)
x 80
Re: diabox 7.57
Unread post by ozfrog »
Paul-R wrote: 05 May 2026, 22:18 What does non vm mean?
I don't want to assume anything, but my guess about the "non vm" means not to run under a virtual machine.
Cheers,
Andrew
x 1944
Re: diabox 7.57
It was my thought as well but I didn't want to presume. The thing is a VM isn't even necessary if you're running 32 bit Win 7 Pro natively. Possibly Win 10 as well.
cit-rotti
x 78
Re: diabox 7.57
Unread post by cit-rotti »
Diagbox 7.57 is a very stable version and is suitable for vehicles up to 2014/2015.
To use this version fully natively, it must be installed on a 32-bit system = Windows 7 32-bit Pro or XP Professional SP3.
If installed on a 64-bit system, LEXIA cannot be used for older cars – or it will be installed as a virtual machine rather than natively.
Newer vehicles from 2015 onwards require a 9.xxx software version. All 9.xxx versions work fully on 64-bit systems.
