Citroen C3 2006 Rough idle and SERV light on
Moyhentaja
Re: Citroen C3 2006 Rough idle and SERV light on
New battery and new altenator! Ecu pins looking brand new. Wigling the wiring loom, connectors & passthrews does not bring fault codes. I will be bringing rthe car in to the local citoren guru to see if they have the right tools and knowledge to diagnose.. They have no lexia tools however. I have also requested used throttle body and throttle pedal from the wreckers to see if that makes any difference. Bet it wont.
ozvtr
- x 244
No disrespect, but new does not mean good!
I would then ask the question; why are the battery and alternator new and when were they replaced? Were they replaced because the alternator died and took out the battery? Were they replaced BECAUSE of this fault? Were they replaced just before this fault?
Engine ECU is still a suspect if you eliminate everything else.
Moyhentaja
I dont know, just bought the car from the auction. I am hoping its not ecu faultozvtr wrote: 30 Apr 2026, 02:39 No disrespect, but new does not mean good!
ozvtr
- x 244
OH, I see. You should have told us that in the first place. We could have moved along a bit quicker.Moyhentaja wrote: 30 Apr 2026, 05:55 I dont know, just bought the car from the auction. I am hoping its not ecu fault
Can I give you a piece of advice on buying cars that don't run? Particularly auction vehicles.
Expect the worst and prepare for long journey to recovery! I do not recommend it for the "feint-of-heart".
I have gone through this process a number of times (see my bio to the left) and I can tell you the cars are rarely in serviceable condition and typically have lots of hidden faults.
HOWEVER, I don't know you and you might "flip" cars for a living. In which case you already know what I'm saying.
If you wish, I can give you a list of things I typically find wrong with the 2002-2010 1.4 (KFV) C3's.
While I'm very familiar with the C3 I do not consider myself an "expert". Most of the C3's sold here in Australia are petrol KFV engined variants. So no dual fuel and no LPG versions. I have not seen a Johnson Controls ENGINE ECU. However I am familiar with the TU5JP4 (NFU) 1.6i engine C3 (typically SENSODRIVE) and that runs a BOSCH ME7.4.4 ECU. There are some 1.6i and some diesels, but I am unfamiliar with the diesels at all!
So my question to anyone would be; do Johnson Controls do an engine ECU for the KFV engine? I can only find VALEO and SAGEM. So is the poster looking at the BSM? Happy to be "educated" on this matter.
Once again, no disrespect to anyone. Just trying to be helpful.
- x 8042
I have deleted the last post which used unacceptable language and a personal insult to another member. Further such posts may result in a ban from the forum !
Moyhentaja
Yeah, car was bought from auction in running condition, no issues. 90k km's on clock, 1 owner, immaculate condition and it really is. I've attached a picture of the ecu for reference.ozvtr wrote: 01 May 2026, 04:50OH, I see. You should have told us that in the first place. We could have moved along a bit quicker.Moyhentaja wrote: 30 Apr 2026, 05:55 I dont know, just bought the car from the auction. I am hoping its not ecu fault
So my question to anyone would be; do Johnson Controls do an engine ECU for the KFV engine? I can only find VALEO and SAGEM. So is the poster looking at the BSM? Happy to be "educated" on this matter.![]()
Update:
I have completed the aforementioned bosch specific "calibration" values EEPROM programming sequence. The ECU infact does the calibration run by driving the throttle valve to its endpoints with that procedure. The car has now worked fine for 2 days, no problems. However when the serv light was on and radio screens says "Engine Manangment Failure" the OBD comms port reader cant find any fault codes. The car just wont respond to the thorttle pedal command and it is running poorly. The Throttle valve does not recieve power at this time when the fault is active.
PaulC5
- x 656
I hope nobody has been criticising ozvtr, he is one of the most helpful people on here and has spent many an hour trying to sort other's problems.
ozvtr
- x 244
Lets keep our fingers crossed.
So the P0122 & P2122 codes disappeared? That's disconcerting. There are a thousand things that can cause the engine to go into "limp mode". I would assume the P0122 & P2122 codes are still there but the reader is not getting data, for one reason or another. I would hope it's not a new fault.Moyhentaja wrote: 01 May 2026, 08:42 However when the serv light was on and radio screens says "Engine Manangment Failure" the OBD comms port reader cant find any fault codes. The car just wont respond to the thorttle pedal command and it is running poorly. The Throttle valve does not recieve power at this time when the fault is active.
IIRC if there any problems with the engine controls after a drive cycle has started, the engine goes into limp mode, but the vehicle still moves. However, if a failure is detected at startup, the engine will not respond to the accelerator.
ozvtr
- x 244
Thank you. I'm only trying to help. I apologize profusely if I have offended anyone, in any way.PaulC5 wrote: 01 May 2026, 11:35 I hope nobody has been criticising ozvtr, he is one of the most helpful people on here and has spent many an hour trying to sort other's problems.
Moyhentaja
The problem was faulty spark plugs, that misfire info would be nice to read from obd. Even the "expert" mechanics at local citoren dealer couldn't find the problem. This was something..
