Hi, my names Milo, I’m new to posting on these forums but I have a question about my c2 gt. I hope I have posted this in the right section. When I got the car it had electric mirrors installed but I believe these didn’t come with them from the factory and was wondering what it would take to get them to work as they are plugged in but I can’t find the wire that connects to the switch for the control panel, where would this wire come out of? Would I need to buy a harness? Or is the a cable I need to buy? Also do the mirrors need coding? And do I need a control unit for them?
Any help would be much appreciated, thanks.
C2 Power Mirrors
- x 8151
Re: C2 Power Windows
You need to go to a dealer and ask them to print your build sheet for the car which will tell you what equipment you have.
ozvtr
- x 255
Your post is very strange!
You have posted a question in the diagnostics area that is not about diagnostics?
The title inquires about power windows and yet the question is about electric mirrors?
The C2 GT came with hand cranked windows.
Some models of the C2 did not have electric wing mirrors (the Furio and Enterprise). But I'm sure the GT had electric wing mirrors.
If both sets of mirrors are not working then the problem is probably in the switch or the fuse.
Check fuse F22 in the BSI.
The BSI is the fuse box inside the cabin. It's behind the steering wheel in a left hand drive car and in the glove box of a right hand drive car.
m1lo505
Oops didn’t realise I’d put windows, I do have power windows and they work but my car came with power mirrors plugged in when I bought it but there isn’t the switch and I can’t find any wire where a switch would plug in.
What topic section would this sort of question be for? I’m very new to posting sorry
Onlinemyglaren
- x 5678
Re: C2 Power Mirrors
Topic moved and title altered
