Hi.
Do anyone know, is it possible just swapping multi-function switch onto steering column, or does it need some software or hardware tweaks ?
Thank You in advance
Adding cruise control
- x 1479
Re: Adding cruise control
You need a diag computer to enable it in the ECU (and possibly BSI as well). Note that some versions of engine ECUs don't support the cruise function so it may not be possible.
- x 1918
Early PSA cars also needed the brake pedal switch to be the 4-pin connector type, not the 2-pin type. But I'm talking early 2000s so you should be OK with that. Best to check though.
