RT6 firmware
This unit is the eMyWay system, also referred to as RT6, RNEG2, or WIPNAV+ for the Peugeot platform and made by Magneti Marelli.
Main Features: The eMyWay colour satellite navigation has high resolution mapping, Bluetooth Telephone & Audio Streaming supported profiles, USB support for Media files & CD
Brandon1998
Re: RT6 firmware
Unread post by Brandon1998 »
Paul-R wrote: 05 Apr 2026, 12:13 If you look at the tables ten posts above this you can see that updating from 2.1 (actually 2.10) is only advised to 2.21 to be good. Any higher version will need a Diagbox session which means going to a Citroen dealer so they can connect to the servers in Paris to download the configuration file for your vehicle. They will charge for this service.
You should be able to use the Mirascripts program to download the current configuration from your vehicle before you go to the higher updates and then upload this configuration to new firmware. This should work although a post above says that they had failure doing this. Mirascripts can also change your configuration (for volume, Bluetooth echo, etc) although I have never done this.
Check your PM for a link to download 2.21. This is a version to load onto a USB stick. Usual disclaimers, use this at your own risk, etc.
Use Mirascripts to download your configuration first just in case of an unforeseen problem. Let us know if this works for you and then, if necessary, I can provide links to later firmware versions.
Hi Paul,
I proceded to the upgrade of the frimware 2.10 to 2.21.
The problem of the bluetooth is yet here but less curently.
I use iPhone 13 mini and the BT version of my C4 is : BT:4.74.1d.
Is it compatible ?
Thanks !
x 1940
Re: RT6 firmware
Brandon1998 wrote: 05 Apr 2026, 17:16I proceeded to the upgrade of the frimware 2.10 to 2.21.
Whilst researching my answer to you I did come across a post by someone who said that had cured their BT problem when the reached version 2.7something (probably 2.77). So maybe do that but if you do there's no going back if it makes things worse.
Did you download your configuration with Mirascripts?
Brandon1998 wrote: 05 Apr 2026, 17:16 I use iPhone 13 mini and the BT version of my C4 is : BT:4.74.1d.
Is it compatible ?
Sorry I do not know anything about iPhones.
rares998
Re: RT6 firmware
Unread post by rares998 »
Hello! Can anyone plase give me link to the RT6 2.86 full Firmware. I can only find the 60/80 Mb update, not the 500/600Mb one. Can any one give me the full version, please?
x 1940
Re: RT6 firmware
We've had something like this before with someone insisting there was a much larger version. It turned out that the poster didn't have an RT6 system at all and was looking at an RT5 (I think) system. AFAIK there is only the 80 MB update for the RT6.
A photograph of the front of your unit might help identify what you have.
rares998
Re: RT6 firmware
I dont know myself what is the memory of the version. Chat GPT said it should have 500/600 MB. It says that the 80 Mb is just an update from the anterior version to the last one. The thing is that my SD card is dead (black screen/nothing working; but my PC can still read the info on it). I just need the 2.86 full Firmware so my radio cand work again. I know the problems it could cause, but i have saved from the original card the essential info of the car.
x 1940
Re: RT6 firmware
rares998 wrote: 12 Apr 2026, 12:11Chat GPT said it should have 500/600 MB.
Say no more.
Did Chat GPT give a reference for that information and did you check it?
rares998
Re: RT6 firmware
I did not checked the reference. I just want the soft that works, I dont care about the size of the document.
x 1940
Re: RT6 firmware
Well that's the 80 GB download then. Do you have 2.86 already or need a link?
rares998
Re: RT6 firmware
No, i don.t have any trused link.
x 1940
Re: RT6 firmware
@rares998
Check your PM.
rares998
Re: RT6 firmware
Thank you so much!
Brandon1998
Re: RT6 firmware
Hi Paul,
Hope you're fine. Thanks for your anwer.
I come back to you aftyer 1 week, I want to be sure that my problem is not temporally. Unfortunatly, he's not...
Yes I download my configuration with Mirascripts?
Here the capture of my USB Key after backup
Do you think that the problme can be my microSD card ?
Can I buy a new microSD card and restore my backup with mirascipt ?
I dismantle my radio, and this is what I have
Brandon1998
Re: RT6 firmware
Hello all,
Any update ?
Thanks.
x 1940
Re: RT6 firmware
Apologies for missing this.
Brandon1998 wrote: 14 Apr 2026, 01:01 Hi Paul,
Well, it doesn't look wrong! You won't know until you try to restore the configuration though.
Brandon1998 wrote: 14 Apr 2026, 01:01Do you think that the problme can be my microSD card ?
Yes, it certainly could. I would suggest you upgrade to an 8GB microSD card though.
Brandon1998 wrote: 14 Apr 2026, 01:01Can I buy a new microSD card and restore my backup with mirascipt ?
Yes, absolutely.
Brandon1998 wrote: 14 Apr 2026, 01:01I dismantle my radio, and this is what I have
The photos don't show much that we didn't already know except that the SD card is 4GB capacity and confirming that the radio is RNEG2 (RT6). It doesn't reveal what firmware version was originally fitted.
rares998
Re: RT6 firmware
Hello all! So all my attempts to put the last firmware on a new microSD card were a failure. It simply didn’t work. Black screen with no result. After many days of trying to repair it I finally gave up. I searched on SH app for another RT6 unit. I found a guy. He told me that he can repair mine. I don’t know what kind of sorcery he’s doing but he somehow found that my unit gets stuck at 80% during the booting process. He replaced the processor of the unit and then he put the last firmware with all the maps on a 16GB card. I sent him my VIN and told him what type of audio pack I have on my car. He put all the new settings on and now my radio is working very well. He also said that he successfully put 32 and 64GB cards in the unit. He’s some kind of a magician :)))).
I’m very thankful that I found him.
PS: The guy is from Romania, Deva. If someone needs his help I can ask him if I can post here his phone number.
