My 2019 DS7 Crossback has had the serpentine belt and tensioners replaced.
Since then it has started making a horrible screetching noise when the engine is started and the fan starts working full blast. Anybody know what could be causing this?
It´s been back to the mecanic to replace the new belt, thinking it could be faulty, but it just continues with this sound.
TIA
DS7 Crossback screeching noise
Linda
- x 8118
Re: DS7 Crossback screeching noise
When you say 'the car is switched on' do you mean the ignition switched on or the engine started?
Onlinemyglaren
- x 5670
I had a similar fault with a C5 that was the alternator clutch.
