Automatic Wipers 3-Beeps
ismlyldz
Unread post by ismlyldz »
Hello,
My car is a Citroën C3 1.4 Petrol, model year 2002/2003.
I’m having an issue with my automatic wipers. As soon as I switch the wipers to AUTO mode, the car gives 3 beep sounds.
After that, the wipers start working at a fixed interval (around every 9–10 seconds) even when there is no rain at all. Other than the initial beeps, there are no additional warnings or sounds.
Has anyone experienced something similar?
Could this be caused by a faulty rain sensor, bad sensor gel, or a connection issue?
Thanks!
x 1952
Re: Automatic Wipers 3-Beeps
How old is the car battery?
PaulC5
x 711
Unread post by PaulC5 »
Is the windscreen clean at the top if there is a rain sensor there ?
ismlyldz
Paul-R wrote: 22 Mar 2026, 10:41 How old is the car battery?
The car battery is at most 1 year old.
ismlyldz
PaulC5 wrote: 22 Mar 2026, 11:55 Is the windscreen clean at the top if there is a rain sensor there ?
Yes, there is a rain sensor, and until some time ago (I don’t remember exactly when), this issue did not occur.
I need to understand what exactly triggers this warning from a technical perspective.
Because removing and fixing that area is quite difficult — it has a rather unusual rear-view mirror setup.
x 1952
As a first step, try a BSI reset.
viewtopic.php?p=601679#p601679
