Citroen C5 2006 2.0 Hdi RD4 to RT3
This section is for General Enquiries or for Systems not Covered Above
sefagenc
Unread post by sefagenc »
2006 Model Citroen C5 2.0 kullan?c?s?y?m. Arac?mda standart rd4 sistem var. Ben Rt3 e geçmek istiyorum. Bütün sistemi toplad?m. Torpido içindeki tesisat da dahil olmak üzere. Tak?ld???m bir konu var. Tesisat üzerinde k?rm?z? kilitli gri soket var ve kar??l???n? bulam?yorum. San?yorum ki JBL ampfilikatörden ç?kan sesi araca da??tan soket tam emin de?ilim. Yard?mc? olurmusunuz?
x 8126
Re: Citroen C5 2006 2.0 Hdi RD4 to RT3
Please post in English, using a translator if necessary, as this is an English Language Forum :)
sefagenc
I own a 2006 Citroën C5 2.0. My car has the standard RD4 system. I want to upgrade to RT3. I’ve gathered all the components, including the dashboard wiring harness. I’m stuck on one issue: there’s a red-locked gray connector on the wiring harness, and I can’t figure out what it’s for. I think it might be the connector that distributes the audio signal from the JBL amplifier to the car, but I’m not entirely sure. Could you help me?
