Citroen Relay wipers fault
x 8013
Re: Citroen Relay wipers fault
Have you checked the fuses? :)
snowglow
Unread post by snowglow »
Any other recommendations gents? My electrical knowledge is limited, but I am prepaed to try if someone can give me advice
snowglow
mickthemaverick wrote: 21 Mar 2026, 10:36 Have you checked the fuses? :)
Apologies Mick, only just seen you post. The fuse list in my manual makes no reference to a wiper fuse?
x 8013
The one reference I found for a MK1 Relay has this fuseboard layout. The two fuses I have arrowed in orange are both labelled special equipment whereas all the others have actual functions not including the wipers. So they may be off one of these, more likely the 30A I would think but worth checking both. :)
BFTW
BFTW
snowglow
Thanks for the info Mick. Just looked at both fuses and both are ok. I really am at a loss
x 1907
I think the next step is to look at the fuses. Here I can't help you and you'll really have to look in your driver's handbook.
snowglow
I have a Citroen Relay with Windscreen wipers and washer that are not working. Parked up, away from home, starter battery was flat and a kind soul jump started my Relay which got me home. A few days later I discovered that my wipers and washer do not work! Can anyone please help me?
snowglow
Can anyone give me some more suggestions please? Getting nowhere with this problem
x 8013
Have you checked the earth connections to the motors?
