So the left tie rod end (or is it called track rod end?) is bad on my 2014 Cactus 1.6 BlueHDI.
For the left side I can find two parts with different diameters. One with total length of 200 mm and inner thread M 10 x 1,25 mm / outer M 14 x 1,5 mm
and one with total length of 210 mm and inner thread M 16 x 1,5 mm / outer M 10 x 1,25 mm.
Which diameter is correct for my car with VIN VF7**************[VIN obfuscated, can be read by forum staff] ?
A part number would be much appreciated.
Picture of the tie rod / track rod end to avoid confusion:
Partnumber tie rod end / track rod end
martin_b
- x 8
- x 8151
Re: Partnumber tie rod end / track rod end
I'm afraid I cannot help with a part number as I only have access to a backup system which covers cars prior to 2013. Hopefully someone with access to the current system will be able to help.
