Where's my BPGA?
x 1938
Where's my BPGA?
Here's a question that I should know the answer to - but I don't. Hence why I'm asking.
Every query I put into a search engine comes up with this kind of picture showing the BPGA that's fitted to the Mk2 Peugeot 308.
But I don't have one of those in front of the battery. There's just an empty space there. Now it does make swapping the battery over a bit easier but I would like to know what's going on. I suspect that it's something to do with the fact that the 308 is an Active trim specification. According to the handbook this has an Eco fusebox. I think that it's Allure specification (and higher) that have the full fuseboxes fitted and that have this type of BPGA.
So, is my theory correct? And, more importantly, what do I have and where is it?
308 VIN VF3**************[VIN obfuscated, can be read by forum staff] if needed (and if you can read it).
x 1938
Re: Where's my BPGA?
As you can see there's no BPGA there.
There is a small fusebox in roughly the same position but that only has three maxi-fuses inside.
x 1489
I think they deleted it from later cars - or used a different design. Our 2017 C4 doesn't have one - just the fuse box as you have.
x 1938
It's not a very late car, 2015.
What trim level is your C4?
x 1055
Unread post by wheeler »
I cant see a BPGA on the parts diagram for your car.
x 1938
Thanks, I didn't think so.
x 1489
Ours is 'feel' trim - the mid spec at this age.
