I don't know if anybody any longer reads this thread or drives these cars, but I have two of them. Just working on the cam belt on a french import where the previous owner claimed it has been done few thousand km's ago. Well, perhaps the belt but not the tensioner and the other roller.
The tensioner can be replaced fine, without problems, without taking out the engine mount if you just release the mounting BELOW the engine so that it can be jacked up bit higher. When you get the tensioner bolt above the steel beam on the car body, everything is fine. Took me about one hour to replace the tensioner even if I had to repair the eccentric tensioner release part by welding and grinding. Someone had destroyed the hexagonal part previously and had to fix that.
Attached two pictures that tell more than 1000 words.
Xantia 2.1TD Cambelt Replacement - Blow by Blow
kimmoa
- x 1996
Re: Xantia 2.1TD Cambelt Replacement - Blow by Blow
Well I have two Xantia as well and I just read your post....I claim my Sultsina
Skull
- (Donor 2026)
- x 381
Re:
I just read this post as well
my old 2.1TD long gone ....
Come on Jim there'll be some guy with his 2.1TD in bits waiting for the reassembly guide.... my HDi cylinder head shouldn't take this long
2008CitroJim wrote: 03 May 2008, 22:40
Tomorrow I'll deal with the reassembly. Mostly it is a straight reversal of disassembly, as the BoL would say...
Gary
Gary
- x 8401
Re: Re:
Skull wrote: 20 Feb 2026, 09:09 I just read this post as wellmy old 2.1TD long gone ....
Tomorrow I'll deal with the reassembly. Mostly it is a straight reversal of disassembly, as the BoL would say...Come on Jim there'll be some guy with his 2.1TD in bits waiting for the reassembly guide.... my HDi cylinder head shouldn't take this long
Ahh, they always say the best things in life are worth the wait
