Timing belt kit.
Hi all can someone point me in the right direction for a timing belt kit for my Wife's 2016 DS5 2.0 Bluehdi.
Do i go for Gates Or Ina?
Barrie
Timing Belt Water Pump Kit
- x 8121
Re: Timing Belt Water Pump Kit
I have used Gates kits on all the changes I've done in the last 15+ years and never had a problem, if that helps!
perrye
- (Donor 2026)
- x 10
I've used Gates or Dayco.
OnlinePaulC5
- x 683
If you go for an aftermarket part it might have a different replacement time/mileage to one from a Citroen dealer. At 10 years old though I would not be leaving it any longer to replace, I have usually done it a few years sooner to save the worry of possible early failure. Do the water pump as well as the tensioner and replace the coolant - I have normally obtained the coolant undiluted, not ready mixed, from the dealer.
Murphbd71
Thanks Guys
I've Gone for The Gates Timing Belt Kit and also The Gates Ancillary belt Kit.
Barrie
Barrie
