Hello everyone,
I am in the process of replacing the timing chain on my Peugeot 207 1.6 THP 150hp (EP6DT), engine identical to the N14 Mini.
I used the shimming tools to lock the camshafts and crankshaft. Everything seems well aligned mechanically. Before the change, the car started perfectly.
But after replacing the chain, the car no longer starts, and DiagBox displays a message:
Inconsistency between camshaft sensor and crankshaft sensor
No other engine faults are present.
Should the inlet phase variator pulley (VVT) be preloaded before tightening?
Some say you have to turn the pulley to the right (clockwise) to tension it, but I can't find any clear tutorial with photos or video for this operation.
Precise explanations (with angle or tightening method)
Photos or videos showing how to preload this VVT pulley
Feedback on this engine (EP6DT or N14 THP)
Thank you in advance for your valuable help
Have a good evening everyone!
