Citroen C5 2011 acceleration issue
dariusmacedonia
Unread post by dariusmacedonia »
Hello guys, im new here.
Long time french cars lover, my first car was citroen CX, then my Renault 25 Baccara, peugeot 407 and now recently got a Citroen C5 from 2011, 1.6 Petrol.
The car is amazing and i love everything about her.
I have only one issue.
When i drive the car normal and accelerate normal, everything is ok.
But when i give it more gas, like when i try to overtake, the car pops up SERVICE on the dashbord, loses power and after 2-3 min the service goes away and is like nothing happend.
I tried diagnosing this problem but nothing came up.
This happens when i give it a litle bit of acceleration.
I would love to hear if some of u have the same issue and any suggestions.
Have a nice day.!
wurlycorner
x 271
Re: Citroen C5 2011 acceleration issue
Unread post by wurlycorner »
Hi,
When you say you've tried to diagnose but nothing came up... What do you mean?
Or you using a diagnostic tool to try and read trouble codes? If so, what tool are you using?
Iain
CX DTR T2 Safari (silver)
dariusmacedonia
I used a diagnostic tool, that scans for codes, but nothing came up. The tool is from the cheap ones for Ali Express. My friend has a laptop with some diagnostic tools and programs, im gonna go to him on Monday, so i will tall u what will pop up. Those are licenced programs.
Kees
x 146
Unread post by Kees »
1.6 THP!!!! Problem engine!!
PaulC5
x 657
Unread post by PaulC5 »
If it has a fuel filter it might need changing.
dariusmacedonia
is there any chance it could be a vaccum leak? maybe someone knows how to check that?
toolfan
x 3
Unread post by toolfan »
PaulC5 wrote: 30 Jan 2026, 22:03 If it has a fuel filter it might need changing.
This would be my favourite too. I have a 2.0 hdi C5 which had the same symptoms years ago. Fuel filter was full of black mud! Long time not serviced.
x 1438
Unread post by xantia_v6 »
Cars with the THP engine often don't have a fuel filter, if there is one it will be under the car near the fuel tank, but I don't think that it is likely to be your problem.
If you accelerate gradually, does the car car get up to the maximum legal speed?
What grade of petrol do you put in the tank?
dariusmacedonia
I will check tomorrow if it has a fuel filter.
i put 95 octane, it says that on the fult tank door, and the petrol we have here in Macedonia is good.
If i accelerate normal, the car has no problem, but if i want to overtake lets say, than the SERVICE comes up and loses power, so i have to change to 4th gear lets say, rev it to 3000 rpm like that for 30 sec and goes away.
dariusmacedonia
just to add, i bought the car in Netherlands, and i drove it 2500 km home. It was ok. This started happening now.
wurlycorner
x 271
dariusmacedonia wrote: 30 Jan 2026, 13:18 I used a diagnostic tool, that scans for codes, but nothing came up. The tool is from the cheap ones for Ali Express. My friend has a laptop with some diagnostic tools and programs, im gonna go to him on Monday, so i will tall u what will pop up. Those are licenced programs.
If it's bringing up a service indicator then it should be logging some kind of fault code - but if it's only a temporary code, a cheapy car reader wouldn't necessarily show that (or if it's logged a manufacturer specific fault code, the cheap code readers sometimes won't show that as they often don't show anything other than generic OBD codes).
Definitely recommend starting point is to use a fully featured diagnostic tool and show if that shows any codes to give direction - if not, monitor live data while driving.
Iain
