C1 rear subframe
solentview
C1 rear subframe
Unread post by solentview »
Picked up an advisory at the last MOT concerning the bushes in the rear subframe of an 09 C1, which I believe relates to the big bushes used to secure the subframe to the bodywork. The fixing bolts are visible in the front bottom corner of the rear wheel arches, left and right. Does anybody know the extent to which the rear subframe has to be dismantled to allow removal/replacement of the bushes? Can access be gained by simply removing the fastening bolts and allowing the subframe to rotate down (with appropriate support, of course) - or does the subframe have to be removed completely from the vehicle? If the former, i might be able to tackle the job myself; if the latter, it is probably a workshop job.
We also picked up advisories about front wishbone/lower control arm bushes at the last MOT, but I have tackled those myself, having practised a few years ago on our Alhambra. Any advice most gratefully received.
x 8156
Re: C1 rear subframe
You may need the part numbers in this diagram which is for a 5 door. If yours is a 3 door it may be different but I don't think so :)
C1 - 0100 03 422105A - SUSP CROSSMEMBR TORSION BAR RECESS DOOR.pdf
Copied from Citroen Servicebox backup
(107.2 KiB) Downloaded 68 times
And the front lower control arm part diagram with part numbers:
C1 - 0100 03 413101A - FRONT PIVOTS AND HUBS-HUB BEARING.pdf
(155.73 KiB) Downloaded 54 times
solentview
Thanks for the useful diagrams.
