FAP low level warning
mperjm
Unread post by mperjm »
Hi guys been following the forum for nearly 5 years and never though I would need to register lol, after watching 1000s of videos, I needed the VIN to know whats the type of tank or pouch I neeed,
I was wondering if any of you could be soooo amazing and tell me If I have a tank to refill or I do need the pouch bag with the Eolys? And if you tell me what kind of liquid is recommeded to use will be an extra help.
My VIN number is this : VF7**************[VIN obfuscated, can be read by forum staff]
thanks in advance so much
PS: I cant check right now because the weather here is so bad and cant even go outside home.
x 8165
Re: FAP low level warning
Unfortunately forum staff do not currently have access to the Stellantis forum allowing us to get build sheets etc from the VIN. There are members with their own access and hopefully one of them will see your post and be able to answer your queries. Good luck :)
PaulC5
x 712
Unread post by PaulC5 »
When the fluid is filled up you will still need a diagnostic to tell the car so the warning will go since the level is not measured but is calculated.
mperjm
Thanks guys, I do have a good diagbox but not at hand now. Would need to drive about 2 hours to get it back.
I needed to know if is a refillable tank but going to try toeay as is sunny and can get underneath my car
mperjm
Any UK brother that can help??? PLEASE lol
x 1952
I have no reference to be sure but I would have thought that, as the car is new enough to have S&S, that it would be a tank. There are many videos on YouTube about how to refill these:
https://www.youtube.com/results?search_ ... pf%2C+fap)
Even if you DO have a pouch then it can be possible to refill this providing the plastic hasn't become too old and hard and then cracked. See this video:
mperjm
Thanks so much Paul, I will give it a try later today.
