Hi everyone,
I'm working on my 2021 Citroën Relay van (registration ND71 VDZ) – it's the 2.2 BlueHDi diesel model. I'm trying to locate and replace the EGR valve (and possibly clean/check the EGR cooler) because of suspected issues. OBD CODE P046C
I've removed the engine cover and taken some photos of the engine bay (attached below if the forum allows), but the rear area is super cluttered with hoses, wiring, and brackets. From what I've read, the EGR valve should be at the back near the firewall, often integrated with the cooler (small rectangular unit with coolant hoses), but I'm struggling to spot it exactly. Any tips
Exact location on the 2021+ 2.2 BlueHDi – which components to move out of the way first (e.g., specific bracket or hoses)?
Common pitfalls or things that go wrong during replacement?
Also, if anyone knows how to confirm my exact engine code/sub-variant from the registration plate (ND71 VDZ) or VIN – I'd really appreciate it!
Thanks in advance for any advice, photos, or links – much appreciated as I'm trying to DIY this to save some cash!
Cheers,
EvasiveSnail (London)
My Vehicle:
RELAY 35 HVY L4H2 ENT BHDI SS 35 HEAVY
Cirtroen Relay 2021 EGR valve issue
- x 8078
Re: Cirtroen Relay 2021 EGR valve issue
You may find this video helpful:
perfidus
- x 6
As you already found in the video above te EGR unit in 2.2 BlueHDI sits in front of the engine, the turbo is on the back. The 2.0Blue HDI have the EGR in about the same place, the difference between them is the cooler for exhaust gas integrated in the valve unit for 2.0.
I exchanged mine much easyer but I also took out the front of the car for other repairs on the same time (A/C condenser etc.)
Those who don't know history are destined to repeat it!
Will27
The video is ford engine think poster has the 2.2 DW12 psa engine have similar problem with mine
PaulC5
- x 670
Not sure but are you asking for some help ?
