Hello everyone,
I need help to find the correct tightening procedure for the injector clamp on my specific engine. I have found conflicting information online.
Vehicle Details:
Model: Peugeot 3008 (2012)
Engine: 1.6 HDi Engine Code: 9HD (listed as 9H05 in documents)
My Specific Parts (verified on car):
Injector Clamp: The single-bolt type. OEM part # 1613181280.
Clamp Bolt: OEM part # 1982G5.
Can you please tell me what is the recommended torque in Nm/daNm for bolt 1982G5?
Or is it a torque-to-yield (torque + angle) procedure? If so, what is the initial torque and the final angle?
Thank you in advance for your expertise!
Need precise torque spec for single-bolt injector clamp - Peugeot 3008 1.6 HDi (9HD)
sofocle80
- x 8119
Re: Need precise torque spec for single-bolt injector clamp - Peugeot 3008 1.6 HDi (9HD)
I don't have access to torque settings I'm afraid but a member with access may see your post and look it up for you. In the meantime you could try phoning your main dealer and asking the mechanics there!
- x 1459
From Peugeot doc backup:
injection CONTINENTAL (engine DV6C )
bolts (Diesel injector fixing flange)
Pre-tighten 0,7 daNm
Angular tightening 80°
sofocle80
