Oil in Coolant?
- x 1463
Re: Oil in Coolant?
To explain the confusion a little: PSA don't list the oil cooler as a separate part, they sell the whole assembly of the filter base with the cooler attached.
- x 8128
Re: Oil in Coolant?
Aah!! thanks for that Mike, it explains my inability to find it!!
Re: Oil in Coolant?
New and used on ebay
https://www.ebay.co.uk/itm/397259072031 ... 7fdaedb114
- x 1994
Re: Oil in Coolant?
Mihael_M
- x 37
Re: Oil in Coolant?
It is a radiator for a gasoline THP engine. It does not fit the 2.0 Hdi.Gibbo2286 wrote: 13 Dec 2025, 11:02 New and used on ebay
The corresponding is Nr. 1103T3.
- x 1994
Re: Oil in Coolant?
Also fitted to Ford Transits.....lots about for about £45-£75
Mihael_M
- x 37
Re: Oil in Coolant?
https://www.autodoc.co.uk/car-parts/oil ... 09-2-0-hdi
At Autodoc it is £24.99 new .
Hannya92
- x 5
Re: Oil in Coolant?
Thanks everyone, I'm not too sure how long this is like that but would this have harmed the engine much?
Like I said, for now car runs fine, maybe a bit underpowered but I'm used to petrol engines
- x 8128
Re: Oil in Coolant?
As the engine oil does not appear to be contaminated you may well be ok. I'd advise a full drain, flush and refill of the cooling system once you have fitted the new part and hopefully it will be OK
Hannya92
- x 5
Re: Oil in Coolant?
Hopefully it's that... I'll be going to the me mechanic this week so I will update this post once I know more
- x 1994
Re: Oil in Coolant?
I do hope you have STOPPED DRIVING the car at the moment ?
Re: Oil in Coolant?
If the passage of the water had been in the other direction i.e. water in the crankcase it would have destroyed the engine.
Hannya92
- x 5
Re: Oil in Coolant?
I have stopped driving this car since I found the issue, I have the mechanic booked in for Thursday to replace the oil cooler and do a flush on the system, hopefully that resolved the issue
ekjdm14
- x 263
Re: Oil in Coolant?
Yes, and even if it does appear to simply be oil-into-coolant one way I'd still recommend an oil/filter change as a precaution. Doesn't take a lot of antifreeze to "poison" the bottom end, a lot cheaper to drop & replace the stuff just for peace of mind especially as the oil filter has to come off to replace the cooler anyhowGibbo2286 wrote: 15 Dec 2025, 12:17 If the passage of the water had been in the other direction i.e. water in the crankcase it would have destroyed the engine.
'96 ZX SX 1.9TD, White, 88k
'12 Mini freebie project
