Carpet / floor removal Drivers side
JeremyMann74
Unread post by JeremyMann74 »
Hello I havd a Peugeot 207 2011 1.4 petrol Envy.
Trying to get the driver side carpet and underlay out to dry out a wet floor
Struggling to get this plastic tab off and do not want to break it. It twists around about 90 degrees in each direction but not 360 degrees. Its also not coming off when I pull it.
Doest anyone know how to get take this off (and or how it is attached)
Please see picture
Thank you.
x 8141
Re: Carpenter / floor removal Drivers side
That looks like a twist and pull but if you've tried that I'm not sure what else there is! :)
PaulC5
x 698
Unread post by PaulC5 »
If you twist it 90° does it then pull up ?
JeremyMann74
Re: Carpet / floor removal Drivers side
PaulC5 wrote: 11 Dec 2025, 21:50 If you twist it 90° does it then pull up ?
Ive tried to lift it up after turning it either side but it didn't feel any looser. If anything it feels tighter as when I turn it 90 degrees and it gets tighter to the carpet (due to the shap being a rectangle and the floor underneath not being level.
