Problems with Peugeot 207cc
Israel1980
Unread post by Israel1980 »
Good morning, I own a Peugeot 207 cc 1.6 vti, I am writing to you from Spain.
Israel1980
Re: Problems with Peugeot 207cc
The car is showing the following fault codes: P1023 and P1025. Valve lift learning fault. I've replaced the Valvetronic motor and the sensor, but the problem persists.
Israel1980
Could you send me the ECU diagrams so I can check the wiring? Thanks
Israel1980
The engine is a Peugeot 1.6 VTi 5FW from 2007
Israel1980
Thank you so much for your help
x 1945
This is a forum of volunteers and if there's no-one who can help then a plea for assistance can quite often go unanswered. But I wish you luck on solving your problem.
