Hello,
I'm looking for the brake cables for my c5 estate from 2008, manual transmission 2.0 L diesel, the electric motor is not broken but the cables have worn out and need replacement. I've looked quite a bit but I can't seem to find the suitable piece for the replacement. If you could help me find how the cable looks, where to order it from etc would be a life saver!
Where can I find the electric brake cable for c5 estate 2008
Bennyc2000
- x 8121
Re: Where can I find the electric brake cable for c5 estate 2008
Which engine and gearbox do you have, information necessary to find the correct diagrams and part numbers?
OnlineKees
- x 148
You have to make them by yourself, otherwise you have to replace the hole unit.
Bennyc2000
Is there some type of instructional video that shows how? Which cable would work the best for this?
OnlineKees
- x 148
This one is from AliExpress for 470 Euro's......
Bennyc2000
And the mod with cables?
cit-rotti
- x 77
Such cables are available on eBay (German).
e.g. eBay item no.: 305852005306
Search for: electric handbrake cable FOR CITROEN C5 III X7 PEUGEOT 508 ...
MGmike
- x 63
That is complete bulls..t. Replacement cable are available and can be changed without replacing the whole unit.Kees wrote: 01 Dec 2025, 19:25 You have to make them by yourself, otherwise you have to replace the hole unit.
MGmike
- x 63
https://www.ebay.co.uk/sch/i.html?_dkr= ... 0handbrake
this seller has them in Poland and I can supply to UK owners
