Considering sleeping in the back of one of these but I'm unsure of the maximum rear load space size. Can anyone tell me the maximum length with the front passenger seat slid fully forward. Any sizes I've found online don't say if the front seat is in use. Also wondering in the models with the folding front seat leave a fully flat area or if its sloping or stepped.
I've slept easily in a 206 with the upright rear seat base removed and passenger seat pushed fully forward. The C3 picasso is slightly longer so hoping to fit in it. Thanks.
C3 Picasso Boot length
- x 8144
Re: C3 Picasso Boot length
If you were OK in the 206 I'm sure you'll be fine in the Picasso but hopefully one of our owners will confirm!!
CitROeNALD
- x 10
If you managed to sleep in the back of a 206, I don't think you will have any problem in the C3 Picasso. Very spacious boot and rear cabin. Probably one of the biggest in it's size class. I used to own one.
It has a nice fold flat rear seats although there may be a void between the boot and the seats you will want to fill. Some have fold down panels to fill/cover this. Also some versions have fold flat front passenger seats.
spaceface
- x 3
I'd imagine it should have a longer load area as the overall length is longer but it depends how far back the front seats are fitted. One online suggestion suggests its OK if you're 5 foot 1 but that doesn't state where the front seat is moved to hence the question. Online specifications don't state where the front seat is when taking measurement. I'm happy to fill a gap between the folded seat and front seat which was needed in the 206.
Ideally I'd go and look but my car is sitting outside undriveable after an accident so mooching around car dealers relies on friends good will at the moment.
PaulC5
- x 698
This might help a bit, it gives the boot length as 1448 mm but you can add a bit on if the front seats are pushed forward. It includes photos of the boot and it seems to show a false floor which can be removed but then the back is not flat https://www.ridc.org.uk/features-review ... r-mpv-2014
