Upstream NOx sensor
Robs931
Upstream NOx sensor
Unread post by Robs931 »
I have a fault code on my 2019 Citroen dispatch van for the upstream NOx sensor (P2A00) and when looking at live data the upstream sensor constantly reads 0ppm so I'm guessing it's failed and needs replacing. Does anyone know the part number for the upstream NOx sensor please? The van is a 2.0l 120hp. Thanks.
Ps. The second fault code for the eolys additive has already been sorted.
x 8083
Re: Upstream NOx sensor
If you post your VIN, which will be obscured from public view, someone with access to the parts database may be able to help you :)
x 1938
Are you sure it's a 2.0 with only 120HP?
Robs931
mickthemaverick wrote: 31 Oct 2025, 16:10 If you post your VIN, which will be obscured from public view, someone with access to the parts database may be able to help you :)
Ok thanks mick, my VIN is VF7**************[VIN obfuscated, can be read by forum staff].
Paul-R wrote: 31 Oct 2025, 16:40 Are you sure it's a 2.0 with only 120HP?
Yeah 2.0l 90kw (120hp) according to the v5
x 1056
Unread post by wheeler »
Only showing one NOx sensor on this vehicle?
x 1056
Looks to be correct
2.0 BlueHDi 120 Pef (DW10FE Euro 6.2) FAP 90KW
perfidus
x 6
Unread post by perfidus »
@wheeler
Euro 6.2 DW10 comes with two NOx sensors. In your picture it's the upstream sensor. The second NOx sensor is on the same spot as in Euro 6 engine, after the DPF.
Those who don't know history are destined to repeat it!
x 1056
It also shows parts 10 & 17 but as tou can see they are not on the parts list on the right, if it doesn’t show the part number it normally means the parts is not fitted to that car.
perfidus
x 6
Try another plan with the deNOx catalyst and possibly it is shown in the SCR system parts, with urea tank.
x 1056
So it looks like the one in the first picture is the upstream one, there is another slide that shows the other sensor (and shows its part number) but lists it as downstream, looks like there is an exchange option for the downstream.
perfidus
x 6
Interesting fact, the two NOx sensors have different part numbers. Might /probably be just the cable lenght but might be also electrical differences.
Robs931
Thank you very much guys, this info is just what I was looking for!
